Corolla instead of Corrola, and code P0440 instead of P0420 makes sense instead of cents...
It sounds like a evaporative system leak concern, possibly faulty Vent solenoid or VSV. Or maybe Leaking Evap hose around Canister area. Your best bet is to have your evap system smoke tested before replacing parts, with enhanced scanner that can close evap solenoid.
OBD Leak Test:
- The test is based on applying a vacuum to the system and monitoring the vacuum over time.
- The ECM (computer) monitors the vacuum level through a Fuel Tank Sensor.
- After some time, the EVAP canister purge valve/solenoid & EVAP vent valve/solenoid are turned ON, allowing the engine vacuum to draw a small vacuum on the entire evaporative emission system.
- If a sufficient vacuum level cannot be achieved, or decreases too fast, a "large leak" or faulty purge valve/solenoid is detected and could set the P0440 code.
This can be caused by any of the following conditions:
- Leaking fuel tank or fuel filler neck.
- Leaking fuel sender assembly O-ring.
- Disconnected or faulty fuel tank pressure sensor.
- Missing, not completely installed or faulty fuel fill cap.
- Disconnected, damaged, pinched, or blocked purge line.
- Disconnected or damaged EVAP vent hose.
- Disconnected, damaged, pinched, or blocked fuel tank vapor line.
- Disconnected or faulty canister purge valve/solenoid.
- Disconnected or malfunctioning vent valve/solenoid.
- Open ignition feed circuit to the vent or purge valve/solenoid.
- Damaged EVAP canister.
Conditions for the test to run (by the control system):
- Certain DTCs are NOT set (from TP sensor, IAT sensor, or MAP sensors)
- System voltage is between 10 & 16 volts.
- Fuel tank fuel level is between 15% & 85%.
- The barometric Pressure (BARO) is more than 75 kPa.
- The Intake Air Temperature (IAT) is between 40°F and 86°F.
- The Engine Coolant Temperature (ECT) is between 40°F & 86°F.
- The startup IAT & ECT are within 16°F of each other.
Clearing the code or turning OFF the Malfunction Indicator Lamp (MIL):
- The code will clear if the fill cap is tightened or reinstalled.
- This DTC can be cleared by using the scan tool Clear Info function or by disconnecting the PCM battery feed.
- The PCM will turn the MIL OFF when the diagnostic has been run & the fault condition is no longer present.
- A "history" DTC P0440 will clear after 40 consecutive warm-up cycles have occurred without a fault.
Notes:
- The control module will illuminate the Malfunction Indicator Lamp (MIL) during the 2nd consecutive trip in which the diagnostic is run and fails.
- The system will store conditions present when the DTC set as Freeze Frame/Failure Records data.
