When is the last time you opened the rear window?
The window might be stuck to the rubber seals around it if you haven't used your rear windows in a while. Had that happen to me once. Have someone press the button, and try to move the window down with your hands (one palm on the outside, one palm on the inside, squeeze the window and gently but firmly pull it downward). That did the trick for me.
EDIT: Don't yank on the window if it absolutely wouldn't budge! It might be the window motor gone dead.
05 engine under a 00 hood! Another 8th gen is back on the road!
