'05 Corrolla Low Beams suck... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-03-2011, 04:49 PM   #1 (permalink)
View Joebklyn's Photo Gallery
USA '05 Corrolla Low Beams suck...
I work nights, driving with the low beams does not provide enuff illumination of the road. The hi beams are great though. Anybody find this to be a problem too? How did you fix it? Thanks Joe
Joebklyn is offline   Reply With Quote
Old 08-03-2011, 05:03 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Clean the lenses with PlastX, align them, and install HIR (Not HID or LED) bulbs. That is the best you can do.
mikered30 is offline   Reply With Quote
Old 08-03-2011, 05:11 PM   #3 (permalink)
|Virus|'s Avatar
View |Virus|'s Photo Gallery
When you say low beam do you mean DRL, Night Lights?
|Virus| is offline   Reply With Quote
Old 08-04-2011, 10:33 AM   #4 (permalink)
Gameroom cash: $113400
View ThetaMike888's Photo Gallery
I replaced my headlights with projectors and installed HIDs in them. This does not blind oncoming drivers and i have never been flashed.
ThetaMike888 is online now   Reply With Quote
Old 08-05-2011, 09:12 AM   #5 (permalink)
Occupation : Foole
View PhantomS's Photo Gallery
It's all relative .... our '05 Corolla's stock lights are WAY brighter than, say, the sealed beam headlights on my late, great '92 Celica..... the difference is like night and day. mikered's advice is sound....perhaps youneed an adjustment and a good cleaning - the PlastX stuff works freakin' GREAT!!!
PhantomS is offline   Reply With Quote
Old 08-05-2011, 03:12 PM   #6 (permalink)
mikered30's Avatar
Philips HIR:
Amazon Amazon
Trimming is required.
Current HIR2-Philips (9006 equivalent): 1875 lumens at 12.8 volts, life of 1400 hours. 3300K temp color.
last generation HIR2 (9006 equivalent) 1700 lumens at 12.8 volts, life of 1000 hours. 3600K temp color.
Philips X-Treme Power (9006) 1140 lumens at 13.2 volts, life of 350 hours. 3400K temp. color
Typical OEM high beam-9005 (halogen) 1700 lumens
After you use the PlastX you must seal/wax the lenses to help block UV rays.
Old 09-12-2011, 04:29 PM   #7 (permalink)
winkzoot's Avatar
View winkzoot's Photo Gallery
USA
I had a similar problem in my '05 XRS. I cleaned the lenses with little result. Changing the bulbs to Silvania Silver Star Ultras made a huge differeance. On my corralla the low beams are also the DRLs so they are illuminated all the time, guess they will need replacing more often than my other cars.
winkzoot is offline   Reply With Quote
Old 09-14-2011, 08:07 PM   #8 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
I just burn off the two plastic rails in the 9005 bulb's plug-in with a soldering gun, and use them in my low beams as well. Affordable and highly effective.
Regular 9006 are 51W, and 9005 are 60W output.
invader is offline   Reply With Quote
Old 09-16-2011, 08:23 PM   #9 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
I used a headlight restore kit on my 05 a couple weeks ago, even though they didn't look that clouded (bought the kit for another car) and the difference is amazing. Just make sure the lenses are clear, and aligned if necessary, and you have a fresh pair of plain bulbs installed.
Avoid any lights that are 'extra white' or anything of the sort, especially the silverstars. The yellower the light output (to an extent) the better you will be able to see, especially when the road is wet. Whiter halogen lights may look nicer, and may make you think you see more, but it's not at all true (this does not include real HID/LED lights). Silverstars and their ilk have a blue-tinted coating on them that blocks out a significant amount of light.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
