The part location may be different, but the principles are the same. Also you can get some useful tips on how to remove the springs & washers. That Ericthecarguy channel on Youtube also has other drum brake videos, you may also take a look.
Here's some helpful hints on tackling the rear brake drum replacement:
1. Remove the wheels.
2. Remove the brake drum from the axle hub.
To install:
3. Install the brake drum.
4. Install the rear wheels, tighten the wheel lug nuts.
There's also another helpful Corolla brakes diagram here: 2004 Corolla Rear Brake Drum diagram. Click on the 'Get Info' button under the Parts Listing tab and a window pops up. Hit the 'Go' button and the diagram will be displayed.
I'll try to post up information regarding the calipers as soon as I can!
I think you've done the hardest part, congratulations! Rotor can be very hard to remove. Various methods are available, like hammer, PD blaster, bolts+nuts. I also learned today that you can jack the front of car on both sides and reinstall the caliper, then start the car, put the gear to D/R, let the rotor rotate and then brake.
For rear drum brake, if you want to replace the shoes, one of the springs is extremely tight. You may need a vise grip. I managed to get it off by a fish hook. There are also special tools for that spring.
Originally Posted by ofogao
Update
I got them off and no need to remove the axle nut.
shoujiliuzhijun, sorry for questioning your expertise
Onward to installing the pads, rotors and calipers and then flushing the brake fluid
For your rear drums, you may want to just inspect them for wear. In my case, I was getting a loud squeal when braking and I thought for sure it was the shoes. After removing the drums, the shoes looked very thick. It turned out the actual drums were warped, so I replaced those for $25 each in 10 minutes, and no more squeal.
1989 Toyota Camry base 5spd (retired at 206,000mi)
2000 Saturn SL2 5spd
2004 Pontiac Grand Am SE1 V6 (totaled due to a rear-end collision)
2003 Toyota Corolla LE
I have a 2007 corolla. I had new brakes put in less than a year ago. I went to PEP BOYS, and the mechanic they did the brake job and had them check the brakes because I hear a grinding sound when I start to stop. They said there is nothing wrong with the brakes or rotors. Also, I just had my car inspected. Again, no problems. But I still hear the grinding sound. There is no problem in Drive or Reverse. So if there is no problem with the brakes or the transmission what could possible be the problem? For some strange reason, I tend to not hear this sound when it rains. PLEASE HELP.
I installed the dust covers, pads, rotors and calipers, however I'm wondering what the torqure settings are for the two bolts that go into the caliper and the two bolts that hold the caliper assembly. Where could I look?
The other question I have regards brake fluid. While I was taking off the calipers some brake fluid came out and now the brake reservoir is empty. Has air gotten into the brake reservoir? How do I get air out of the air reservoir?
