guys I really need some experts to weigh-in here.
I'm chasing a problem or problems and trying to get down to the REAL issue. I've already thrown $550 at it, about to spend on 4 tires, but they'll just go bad again if I don't get the issues.
This is a 2003 LE model, auto, abs, alloys [oem/toy]. Has 153,000 miles. I last put 2 EXPENSIVE goodyear assurance tires on the front, but my son [college] let it go too long before rotation and those two, and the two BFG's on the rear are cooked.. the fronts only lasted 27K miles. The rear tires are showing BAD uneven wear, but we can't recall if they did front duty or rear so I"m wondering where to start? The discount tire guy said that somewhere, maybe several somewheres on the cars, is a bad strut, or bad out-of-alignment or something.
I just had all four bearings replaced and the noises did change... got a lot better with two new bearings in the rear. As bad as the rear tires are, and as old as the bearings are, this may be the "whole problem" or it may not be.
what other items re: wheels/tires do I need to look for at this mileage? would you just go ahead and replace all four tires, drive it, and just see what happens in the first thousand miles??
and on the tires... I would rather have QUIET, cushy tires, vs. long tread life and 'sports' handling... What tires have you guys found that meet that criterion? I know on my Camry, the Assurance Fuel Mizer is a reasonably quiet tire, but on the front of the Corolla, they seemed rocky-hard and noisy.... so I'm a bit baffled.
oh, as to alignment, all I can say is that's the one thing that seems ok... at 60mph on a good road, it tracks quite straight... not pulling at all, which is amazing given the condition of the tires.
Thank you for your advice!!
