Center Dash Console compartment lid broke 2004 LE corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-12-2011, 01:38 PM   #1 (permalink)
2004 Toyota Corolla
View billisnice's Photo Gallery
Center Dash Console compartment lid hinge broke 2004 LE corolla
Wood-grain. I think the unit part # 55420-02171-B0
Is it hard to replace the console and where can i get one inexpensive? I can have some else replace it if to hard.
Thanks
billisnice is offline   Reply With Quote
Old 08-12-2011, 09:41 PM   #2 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
It's very easy to remove after popping the shifter cover off, then removing 2 screws at its base and 1 screw in behind middle fan speed knob.
I replaced the commonly broken upper door's broken left plastic hinge with a screw from old sunglasses... Works perfectly.
invader is offline   Reply With Quote
Old 08-12-2011, 09:58 PM   #3 (permalink)
2004 Toyota Corolla
Do you have a photo of where i put the flat head screwdriver to pop the shifter cover off. I will have to get another one unit, mine is broke so no screw will work.
Thanks
Old 08-12-2011, 10:00 PM   #4 (permalink)
Mine is manual and it pops off by pulling up on it... Is yours automatic?
Mine was broken too, but it's permanently fixed now.
Old 08-12-2011, 10:06 PM   #5 (permalink)
If it's an auto, this might help:
How To Replace 2004 a Corolla Shifter Light?
Old 08-12-2011, 10:30 PM   #6 (permalink)
2004 Toyota Corolla
It is automatic
Old 08-18-2011, 02:22 PM   #7 (permalink)
2004 Toyota Corolla
Yes, it is automatic Still not sure how to take it out.
Old 08-19-2011, 01:06 AM   #8 (permalink)
Using a screwdriver, disengage the 6 claws around your gear selector lever surrounding panel. Tape the screwdriver tip before use. Disconnect the lighter socket and lamp connectors, then remove the panel to access the 2 lower screws on center dash compartmet panel.
