Hello everybody! I got a situation. I got a corolla 2005 CE automatic engine 1ZZ-FE.
there was a flood and I though I could have make it but suddenly the car stop and wouldn't turn on. Had to pay for a truck to take it to my house.
To my surprise the engine sucked water tru the intake since the filtet was wet. I dry the filder and try to start the car but no luck. after starting for bout a hour. the car turn on then off, after a while it turn on but with that weird tickling noise. the more I accelerate the louder it is.
Things I did:
1.Remove the searpent belt and still with the noise. by doing this I confirm is not the pulley, compresor, water pump, etc..
2. Open the top cover and bottom engine cover and removed all gunk in there. change oil with 10-30 castrol and a motor treatment for the lifters. stilll no luck
the only thing I havent check is the timing chain tensioner but I heard is very uncommon to be bad, specially on a car of 2005.
Some people fix the problem by replacing the pulley and others by changing their manifold.
WHat in the manifold that could maybe make it rattle?? I heard this from a guy from youtube so I dont know if its true.
The noise is very similar to this one from the video of someone having the same problem.
