Corolla 2005 Ce alignment Question
I replaced two rear tires in my 2005 Corolla CE (at that time milege 57K) about 6months ago by sears. Also they did wheel alignment. Now after 3K miles, when I went for a tire rotation, they mentioned that my car needs wheel aligment.
The specs from alignment pix are as follows:
Total Front Toe left: The arrow is on 0.10 degrees.
Total Front Toe right: The arrrow is on 0.10 degree
Camber Left front: The arrow is more towards -1.1 degree (scale is 0.4 to -1.1 degree)
camber right front: The arrow is again towards -1.1 degree (scale is -1.1 to 0.4).
Total Rear Toe: Both for left and right the arrows are center of -0.05 to 0.22
Camber Left Rear: The arrow is center of -0.9 to -1.9 degrees
Camber Right Rear: The arrow is more towards -0.9
Does it need alignment
Thanks
Venky
