Absolutely. Get the revised Toyota gasket. You can then reset the ECM by removing the blue 15A EFI fuse in the underhood fuse panel, or by removing the battery to be safe before removing intake manifold which sits above live starter and alternator cables/connectors. No need to drain coolant, as you can set the throttle body aside (and clean it) without unhooking its coolant lines.
You could also remove and clean the IAT/MAF sensor on the intake, with electrical or brake cleaner spray, and wipe the exposed IAT sensor head.
