I have a 04 same model(silver) with 151K basically the exact same as yours 03/04 were the same! Mine doesn't burn any oil ether, at 151K no problems with the engine/tranny or leaks, but my check engine light did come on twice one was an rear oxygen sensor which I replaced myself for $60(very easy), and a faulty fuel cap $25. I changed the plugs at 90K, three sets of tires, numerous wheel alignments, three front brake jobs(pads and rotors) one rear (shoes) + wheel cylinders leaking had to be replaced, three batteries, one rear wheel bearing(driver)...My alloy rims are chipping, replaced my serpentine belt twice and the tensioner once, my windshield washer pump rusted and cracked in half, my headlights were fogging and had to be replaced(under warranty)my front seat brackets are rusting, front window needs replaced from road chips/cracks, brake rubber pad replaced, my dash console tray broke, hinges on my center console broke($30 for 2 hinges from Toyota), my windshield sprayer nozzle plugged up and had to be replaced under warranty, one front wheel liner had to be replaced, rear door handles are leaking rust, weather stripping on my rear doors came loose, I lost one trunk tail light inspection cover that Toyota wants $26 for the 6 inch piece of cloth! but my car runs fine and sometimes I can push 42 mpg on trips, I love it!
