Help Replacing Belt Tensioner Pulley - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-01-2011, 07:59 PM   #1 (permalink)
Gameroom cash: $125000
View matrixjim's Photo Gallery
Need help on replacing the belt tensioner pulley.
Once the belt is removed.
Do you need to remove the entire Tensioner assy to replace the tensioner pulley? Or can you just remove the bolt holding the pulley to arm to replace the pulley.
What are all the torque spec for the tensioner pulley bolts
Thanks for your help.
Jim
matrixjim is offline   Reply With Quote
Old 09-03-2011, 09:31 PM   #2 (permalink)
View tigerclaws1318's Photo Gallery
Best way to replace the tensioner is to first remove the motor mount. Jack up the car and place a piece of wood underneath the oil pan. Lower the car enough where the motor can rise up and that you are able to reach the bolt for the tensioner.
tigerclaws1318 is offline   Reply With Quote
