Corolla 2004 AC is stuck ON - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-05-2011, 11:31 AM   #1 (permalink)
View hamid2535's Photo Gallery
Hello every body,
I bought a uesd 2004 Corolla and I feel Cold when I turn on the Fan even without the A/C botton ON. it looks once I turn the Fan on, and it is on Blue area, the Cold air start to blow. soem times it is not really as Cold as A/C but it is colder than outside temprature.
Any input appreciated,
Thanks
hamid2535 is offline   Reply With Quote
Old 09-06-2011, 09:04 AM   #2 (permalink)
any input?
Old 09-07-2011, 02:35 PM   #3 (permalink)
View bionictony's Photo Gallery
where is your climate control pointed? if air blows up at the windshield, it is in defrost mode and ac compressor is on. turn the dial so air blows through the vents.
bionictony is offline   Reply With Quote
The Following User Says Thank You to bionictony For This Useful Post:
hamid2535 (09-07-2011)
Old 09-07-2011, 03:15 PM   #4 (permalink)
so it defrost it with Cold air? that should be hot air, isnt it?
Old 09-07-2011, 06:24 PM   #5 (permalink)
ems
View ems's Photo Gallery
Hamid it defrost with the temp that you set. But, when you put the dial on defrost the A.C turns on to provide dry air which will defrost the windshield.
ems is offline   Reply With Quote
The Following User Says Thank You to ems For This Useful Post:
Old 09-07-2011, 09:10 PM   #6 (permalink)
That is True, I tried it and you guys are Correct. When I turn it to Windshield and Temperature is on Cold area, the Cold Air start to come. I did not know about this, I taught that only direct the Air , not defrosting.
THANK YOU
