Originally Posted by netpicker9
I am driving 2004 corolla. From past two months my front tire (1 tire) loosing air slowly. I am using tire inflation to increase the PSI. I am doing it every 3 days..
Maybe there is tiny small leakage.. Is there any way to fix this? I have seen tire fix liquids in wal-mart, can any one tell which one recommended? Please suggest me a product.
Thanks
Years ago I used "fix-a-flat" which is one of those products. Sealed the tire real good. 270 miles down the road while doing 70mph on the Interstate the tire blew up. This can be an issue with those products. Another problem assocated with those products you buy at Walmart and other autoparts stores, once you install it, most tire places will no longer remove and mount new tires on that rim. It's a messy gunk and hard to remove and these places may refuse to dismount the tire. Get it fixed right. If you can't do it yourself then take it to a tire place and let them patch/plug the hole. It could also be a bad bead seal or possibly the valve stem is leaking.
