Lights gone trying to install led plate light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-12-2011, 10:19 AM   #1 (permalink)
ukeacreator's Avatar
View ukeacreator's Photo Gallery
ok so i have a big problem with my 2004 , i was trying to install a led plate light that i bought thanks to the horrible instructions i now have no lights on my gauges or on the inside and i have no plate light. Ok so i seen two wires on the inside of the trunk that lead no where and they were green/white and black/white wires so i cut them and tried to get power from them...didnt work then i cut the stock plate light wires and tried to attach them .... didnt work also....if someone could help me get my lights working again i would appreciate it
ukeacreator is offline   Reply With Quote
Old 09-12-2011, 02:16 PM   #2 (permalink)
View Alexcorolla's Photo Gallery
Have you check your fuse box?
I may be fuse blow away.
Alexcorolla is offline   Reply With Quote
The Following User Says Thank You to Alexcorolla For This Useful Post:
ukeacreator (09-13-2011)
Old 09-12-2011, 04:39 PM   #3 (permalink)
I havent checked it but probably wouldnt know how to fix it anyway, i will check though
Old 09-12-2011, 06:33 PM   #4 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291852
View gold94corolla's Photo Gallery
Dude, you don't just go cutting wires any old place you have no clue what you are doing. You probably blew a fuse, so check that, but you want to fix the wires first. And with the LEDs, did you try swapping them 180 degrees in the socket? They only light one way.
gold94corolla is offline   Reply With Quote
The Following User Says Thank You to gold94corolla For This Useful Post:
Old 09-13-2011, 08:41 AM   #5 (permalink)
yes it was idiot but i was just so frustrated, i have been trying to get it to work for so long and yes it was a blown fuse thanks guys
