Shaking steering wheel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2011, 09:35 PM   #1 (permalink)
View Sepal's Photo Gallery
Hi yall. I have a 2005 Toyota Corolla S: manual gearbox and 211,000 miles. This car has been so reliable (needed just a clock in 211,000 miles outside of regular maint.) however now it's having its first seemingly major problem. When I accelerate onto the freeway (not all onramps cause this) the steering wheel will start shaking violently for about 3 miles down the freeway at 50-90 MPH (speed does not matter), and then it will smooth out to normal. I have had the tires balanced twice and it otherwise drives farily smooth, I just don't get the shaking for 3 miles part.. ..Anyone have an idea on what might be going on here?
Sepal is offline   Reply With Quote
Old 10-08-2011, 11:32 PM   #2 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
Are you on original struts and front wheel bearings? How are your ball joints and control arm rear bushings? Tires are in good condition?
invader is offline   Reply With Quote
The Following User Says Thank You to invader For This Useful Post:
Sepal (10-09-2011)
Old 10-09-2011, 01:06 PM   #3 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
1 - Most likely, your wheel balancing or alignment is out. Get your wheel balanced again and see if it works. If that does not work then try get an alignment.
2 - While you are at it, get your front tires checked. Seem if there is a bubble anywhere on either of the tire. Sometimes tires become defective and get a bubble on the tread which results in vibrations at highway speed.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
The Following User Says Thank You to silver04rollas For This Useful Post:
Sepal (10-09-2011)
Old 10-09-2011, 01:33 PM   #4 (permalink)
The struts and bearings are original. It has a 6 month old set of Falken Ziex ZE 912s (about 25,000 miles on them) and had an alignment just a few months ago. The tries are wearing normally. I'll check into the bubble thing, but even when the tires are rotated this shaking still happens after accelerating onto certain onramps and will last 2-3 miles of freeway driving and then smooth out to normal.
Old 10-09-2011, 02:37 PM   #5 (permalink)
Gameroom cash: $125000
View matrixjim's Photo Gallery
check your CV axle, worn CV joint, any torn boots.
Any pulsing on the break pedal when breaking?
matrixjim is offline   Reply With Quote
Old 10-12-2011, 08:24 PM   #6 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Brakes will also do that as well... warped rotors or a ceasing caliper.
Old 11-19-2011, 07:34 AM   #7 (permalink)
View tygerpro357's Photo Gallery
easy way to check the balljoints/struts is to jack the front of the car up from the lower control arm so the wheel comes off the ground but the suspension stays under load and try to wiggle the tire from left to right, using a pry bar try to gently lift the tire up and down, and on the diagonals try to wiggle it (i.e. top left and bottom right) if it wiggles on any of those then you have a bad suspension component and that would cause a steering wheel to shake until the suspension parts settle again
tygerpro357 is offline   Reply With Quote
Old 11-19-2011, 11:33 AM   #8 (permalink)
03' corolla 02' tundra
View alligatorgar's Photo Gallery
you are over due for struts.
alligatorgar is offline   Reply With Quote
Old 11-19-2011, 12:32 PM   #9 (permalink)
ASE Certified Master Tech
View MasterTecInSTL's Photo Gallery
You said you balanced them but did you rotate them? If you have a bad tire in the front moving it to the rear should move the vibration from the steering wheel to your butt.
With that many miles you can't discount anything. In all honesty I'm thinking of a possible transmission or axle issue here...
MasterTecInSTL is offline   Reply With Quote
Old 11-19-2011, 12:44 PM   #10 (permalink)
View kevbot13's Photo Gallery
Same issue as OP
05 Corolla LE automatic with a little over 90k miles and I get the same shaking steering problem as OP, it's most notable when braking at higher speeds though...
kevbot13 is offline   Reply With Quote
