The battery is 2 yrs old. You must excuse my description. I tested the battery it reads 12.6. I tested the power to starter it reads 12.11, than i tested the ignition wire for contingency. Nothing. From what i have gathered in my research, it must be the neutral safety switch or the ignition it self.
How do i test that. I have not yet done any research so any comments would be more than welcome.
Thanks,
Sash.
EDIT: Wow id rather it be the starter. NSS is around $250 for this car, and the starter is only $130. Its crazy!
EDIT2: So after about 2 hours calling around for a NSS I had a crazy idea to test the starter again, this time using a multi meter, testing for Volts not contingency. It was getting volts. Next step test the starter motor, brought it over to a local advaced auto and it turns out that the starter was the culprit. Thank you to all for prompt replies!
