07 Corolla Engine troubles - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2011, 08:25 PM   #1 (permalink)
View corner27's Photo Gallery
My father in law has a 07 Corolla. He was passing a vehicle and heard a bunch of rattling coming from the engine and it went dead. He got it towed to my house and now it will not start. The starter clicks like the engine is locked up.
We checked all the fluids, they look fine. We booted the battery to make sure it had power. We also took a wrench and spun the accessory belt to make sure that none of those components were causing a bind.
Any suggestions?
corner27 is offline   Reply With Quote
Old 10-21-2011, 08:40 PM   #2 (permalink)
Toyota Tech
beantickler's Avatar
View beantickler's Photo Gallery
Is the engine locked up? Can you turn the crank?
beantickler is offline   Reply With Quote
Old 10-21-2011, 08:49 PM   #3 (permalink)
When you try to start it, it just clicks. And the lights go dim.
Old 10-21-2011, 09:34 PM   #4 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Did he get the ECU recall performed?
mikered30 is online now   Reply With Quote
Old 10-21-2011, 09:37 PM   #5 (permalink)
I don't think so.would that have anything to do with it? Seems more mechanical than that.
Old 10-21-2011, 09:46 PM   #6 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
I agree with Mike... If your battery's good, it's likely the original ECU that is failing.
invader is offline   Reply With Quote
Old 10-21-2011, 11:28 PM   #7 (permalink)
Are you able to crank the engine over at all with the starter and with booster cables, or by turning the crankshaft pulley bolt?
Old 10-21-2011, 11:51 PM   #8 (permalink)
If it's manual, can you move the car and turn engine over a bit with it in 5th gear? Was it possibly downshifted in 2nd instead of 4th at highway speeds? A catastrophic engine failure is not impossible.
Old 10-22-2011, 01:33 PM   #9 (permalink)
We called the dealership and they told him the battery was most likely dead. We put a new battery in, and of course it's the same thing. It's as if the starter is trying to turn, but it can't.
It's an automatic, so we can't try to push start it.
Old 10-22-2011, 02:36 PM   #10 (permalink)
mikered30's Avatar
Can you put a code reader on it?
Old 10-22-2011, 03:20 PM   #11 (permalink)
I don't have the means to check codes here.
Old 10-22-2011, 04:46 PM   #12 (permalink)
mikered30's Avatar
Your next step would be to find someone that can borrow you one, hopefully with the new battery the code is still stored, if there are any. How many miles on it?
Old 10-23-2011, 08:46 AM   #13 (permalink)
View zfjohnson07's Photo Gallery
problems..
i dont know if this would help, but i was at the dealership the other day and the service tech told me when you put a new battery in you it will die within the next 15 minutes, because the ecu and stuff resets... hope this helps
zfjohnson07 is offline   Reply With Quote
