FIX!!! Low Idle/Reverse Shake
Guys,
You knwo what I mean. Car is started and it shakes like the dickens but when you get over 1k rpm she runs fine. Reverse.. sometimes she stalls aftre the shakes. Your low on freon.
I know your like WTF? NEWBIE!!
Seriously I didnt believe it when I did it. I have done all the same stuff as you fellas. Clean the tb, iac, mas/map, I even pulled the fuel pump and cleaned the screen on the bottom (yes the in-the-tank one)
All of this.... nothing!!!!
Then my wife said she was hot and wanted coldere air.. I know right?! So I had a can of R134a Stop Leak in the garage, started putting in in and was shocked!! The shakes went away! Not believeing it I killed it, started back up... no issue!!
I even drove around the block in reverse at idle pull me speed.... no stalling or shakes. Absolutley Amazing!!
So for all you guys facing the same issue.... try a can of freon.
57_Belle
(06 Corolla 90k)
