Tire noise can sound exactly like differential whine at speed. Might be worth a shot to rotate the tires around, see if the noise follows the tire(s) or stays the same.
Could also be noise from the electrical systems - changes with RPMs as well. Both my 2002 Corolla and 2003 Matrix did it at highway speeds, where it is easier to notice the sound. Double check chassis grounds, make sure the battery is up to snuff. Both of my cars, the OEM battery just flat out died on me, before I expected them to.
