so through the research ive done, ive found that the optitron gauge from the 2005+ LE plug and plays with the 2003-2004 corolla, but a couple of extra lights and the fuel gauge doesnt work. from what i know the fuel gauge works from the fuel sender sending a resistance reading to the gauge. i want the optitron gauges in my car bad enough so im taking it on myself to solve the problem. i did a reading of the fuel sender resistance from a near empty tank (last line) to a right below half tank (1 line below half). the readings i got was 107ohms for empty and 67ohms at under half tank. so the wiper on the fuel sender reads a low tank as high resistance and a full tank as low resistance. what i have to do now is find a reading from a 2005+ corolla and find what the empty resistance reading is. if its just a lower resistance i can add in a resistor inline from the fuel sender to the gauge but if its at a higher resistance or reversed (ie full tank = high resistance/low tank = low resistance) then im going to have to look into ways of switching the fuel sender unit. anyone want to chime in with their input?
