here is what I am doing:
Key in ignition, turned to on position. Door closed and unlocked.
open driver's door
turn key to off position, and remove it
re-insert key without turning it, then remove it, repeat 4 times
at this point the key is out and door is still open
hit driver's unlock (the rear side of the lock/unlock switch in the armrest) 5 times
wait ten seconds, shut driver's door
the above is not working. After I do this, the car is not acting any differently. I am also not getting the confirmation at the end of the process, such as the dome light flashing or the locks locking and unlocking once, like you get when you successfully program your remote. Any suggestions?
