I guess there is a reason you don't want to take it back.
Did it do it right when you got it. Maybe they never cleared the stuff out after the service. Usually one or two good full throttle pulls will get the stuff out. It could also be they fouled the spark plugs. Did you check those. It is impossible to switch coil or injector connections on a 1ZZ so I would make sure the coils are all plugged in. A coil could have failed but is unlikely.
You do not adjust timing on a 1ZZFE it is controlled by the computer and is nearly impossible for them
To have messed with it short of taking your chain tensioner out and turning the engine over or taking off the front cover.
Reason: R
