Dash lights and running lights not working... help please!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2011, 03:53 PM   #1 (permalink)
View nick64cap's Photo Gallery
Unhappy Dash lights and running lights not working... help please!!!!
Hello everyone, I have a 2005 Corolla S. I recently did a head unit install and when night time hit I got pulled over because my running lights and my dash lights are not on. So I know when I took the dash appart that I had to of knocked something loose that cut the power to the dash lights and my night time running lights. So I'll be pulling the dash all apart again in order to fix this but the problem is I have no idea what cord or cable could have been pulled loose. So if you guys/girls could help me identify which cord I need to be looking for it would be greatly appreciated. Thanks!
nick64cap is offline   Reply With Quote
Old 11-09-2011, 07:23 PM   #2 (permalink)
its a non-prius ha
AzN-BriaN's Avatar
View AzN-BriaN's Photo Gallery
check your fuses/relays
AzN-BriaN is offline   Reply With Quote
Old 11-09-2011, 07:34 PM   #3 (permalink)
Ohiowa's Avatar
View Ohiowa's Photo Gallery
Was it just a head unit swap or did you do more? Running amp power cables may have disconnected or cut something in the harnesses under the dash.
Pure speculation, since I don't know exactly what you were doing in the first place.
1989 Toyota Camry base 5spd (retired at 206,000mi)
2000 Saturn SL2 5spd
2004 Pontiac Grand Am SE1 V6 (totaled due to a rear-end collision)
2003 Toyota Corolla LE
Ohiowa is offline   Reply With Quote
Old 11-09-2011, 07:58 PM   #4 (permalink)
I check my fuses earlier today but I couldnt figure out wi\hich one I should be looking for. When I did my head unit install I only replaced the head unit. The biggest hunch I have is when I pulled my dash apart I took the center part with the temperature connections and I let it hang to the side so I think I might have put too much stress on the cables . idk thanks for the ideas so far but still no luck
Old 11-09-2011, 08:08 PM   #5 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Check 15, it is above the odb II port up under the dash. If it keeps blowing you have other issues.
http://i16.photobucket.com/albums/b4...elocations.jpg
mikered30 is offline   Reply With Quote
The Following User Says Thank You to mikered30 For This Useful Post:
nick64cap (11-10-2011)
Old 11-10-2011, 12:08 PM   #6 (permalink)
I'll try that when I get off work and let you know how it goes,thanks for the help so far
Old 11-10-2011, 05:22 PM   #7 (permalink)
Gameroom cash: $172005
View bennor's Photo Gallery
When you installed the new head unit did you use a premade wiring harness (designed for the Corolla model/year you have) to connect the new head unit with the oem radio wiring harness? Or did you make your own harness or simply cut and splice the wires on the OEM radio harness and then crimp/solder the wires to the new head unit's wiring harness?
After checking, and replacing if needed, the fuses, check the wiring harness that connects to the new head unit, possible the head unit harness wires may be crossed or grounded accidentally which will cause a fuse to blow every time you use the new head unit or turn the car on.
bennor is offline   Reply With Quote
The Following User Says Thank You to bennor For This Useful Post:
Old 11-10-2011, 06:12 PM   #8 (permalink)
yes I got a wiring harness from best buy when I bought the head unit. But I still had to splice some wires and did a sloppy job. If a go and fix the wires how can I reset the fuse to see if the lights are working or will I need to replace the fuses.
Old 11-10-2011, 07:44 PM   #9 (permalink)
thanks so much! your diagrams helped me out so much! found the instrument panel and sure enough fuse 15 was blown. Replaced it and everything is working just fine. thanks again you guys freakin ROCK!!!
Old 11-10-2011, 07:58 PM   #10 (permalink)
mikered30's Avatar
Does it blow again when you turn on the radio?
Old 11-11-2011, 05:52 AM   #11 (permalink)
No. I redid all my connections on my head unit and made sure it was all nice and neat.
