Catalytic Converter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2011, 05:32 PM   #1 (permalink)
View Ashadia's Photo Gallery
Catalytic Converter
Hellos, i need a catalytic converter for my car and the place i took it to to get checked was going to charge me almost 1k to get it fixed - im pretty sure it doesnt cost that much and its the only part they were going to get. So i was wanting to buy one online instead and try to save some money. But i have no idea what to look for? Can anyone give me a specific part to look for? Whenever i look i get about 15 different results and im not sure which one i need. I have a 2003 Corolla S. Any help is much appreciated <3
Ashadia is offline   Reply With Quote
Old 11-11-2011, 06:21 PM   #2 (permalink)
its a non-prius ha
AzN-BriaN's Avatar
View AzN-BriaN's Photo Gallery
Look for an OEM spec aftermarket like Magnaflow OEM diameter is 2in anyone correct me if im wrong on the diameter part
AzN-BriaN is offline   Reply With Quote
Old 11-11-2011, 07:46 PM   #3 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Are they sure it is not an O2 sensor?
mikered30 is offline   Reply With Quote
Old 11-12-2011, 03:51 PM   #4 (permalink)
they have it down as both - i checked the diagnostic again, and its 1k for the Catalytic converter and two O2 sensors - but i still think its high...
Old 11-12-2011, 05:08 PM   #5 (permalink)
its a non-prius ha
AzN-BriaN's Avatar
Where are you going... the dealership?? I would just find a local reputable exhaust shop if I were you.
Old 11-12-2011, 09:30 PM   #6 (permalink)
Ohiowa's Avatar
View Ohiowa's Photo Gallery
http://www.jegs.com/i/Magnaflow/642/93200/10002/-1
http://www.jegs.com/i/Denso/313/234-4233/10002/-1
1989 Toyota Camry base 5spd (retired at 206,000mi)
2000 Saturn SL2 5spd
2004 Pontiac Grand Am SE1 V6 (totaled due to a rear-end collision)
2003 Toyota Corolla LE
Ohiowa is offline   Reply With Quote
Old 11-13-2011, 03:55 PM   #7 (permalink)
ASE Certified Master Tech
View MasterTecInSTL's Photo Gallery
I'm showing the OE part numbers as 17460-0D070 and a dealer list price of $1447.75 for the part.
However there is a TSB posted for a redesigned converter/front pipe assembly that is available to correct a sulfur smell and a P0420. Its part number is 17410-0D360. A computer programming update is also supposed to be done when this converter is installed. I don't have dealer list price available for this with my info but I did find one for sale online for about $800 (plus shipping).
I also found some aftermarket options available for about $300-350 (plus shipping). Some are the complete front pipe assembly with "universal" style converters already welded on. Others are the converters only and will need to be welded on to what's left of the front pipe after cutting them off. Regardless "universal" converters generally aren't a very good idea. Since they are not specifically built to your cars specs they may not work well enough or last long enough to last nearly as long as the factory converters. It's also illegal to use Universal Converters in some "green" states - especially California.
As for the Oxygen Sensors... they probably aren't necessary but if you have over 100,000 miles on the cars might be worth it for maintenance purposes. Since they have to be removed anyway to do the computer there should be no extra labor for replacing them.
MasterTecInSTL is offline   Reply With Quote
