'08 corolla camber question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2011, 01:06 AM   #1 (permalink)
View krnzilla's Photo Gallery
Are there any camber kits available for the 9th gen corolla?
If not, what's the next best option? Shims?
Thanks.
krnzilla is offline   Reply With Quote
Old 11-12-2011, 04:38 AM   #2 (permalink)
its a non-prius ha
AzN-BriaN's Avatar
View AzN-BriaN's Photo Gallery
Why do you need a camber kit?
AzN-BriaN is offline   Reply With Quote
Old 11-12-2011, 12:13 PM   #3 (permalink)
My mechanic told me there was a slight negative camber in my rear. Dont remember which one but he advised I get it fixed.
Side note: I think i remember you from 9gc. Werent you a mod?
Old 11-12-2011, 02:36 PM   #4 (permalink)
its a non-prius ha
AzN-BriaN's Avatar
Go for a full alignment which then they will shim.
yea was
Old 11-13-2011, 04:04 PM   #5 (permalink)
ASE Certified Master Tech
View MasterTecInSTL's Photo Gallery
For the rear all you can do is have a shim installed. Be careful though it's not normal for the rear camber to be out of whack on these. If a mis-calibrated alignment machine was used it could simply be giving the incorrect readings.
I've fixed many, many issues like this by REMOVING shims that were previously installed. My theory is that the shop who did the last alignment didn't calibrate their equipment regularly so they though the angles were off when in fact they really weren't.
How far out is it? If it's right on the line of spec (or even .1/.2 degrees out) then shimming it might not be worth it, especially if the tire wear in the rear isn't abnormal.
MasterTecInSTL is offline   Reply With Quote
