Corolla deprogrammed when change the battery - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2011, 12:47 PM   #1 (permalink)
View antalus's Photo Gallery
Exclamation Corolla deprogrammed when change the battery
Why the ECU is deprogrammed every time I remove the bettery?(don't start engine)
I should do to make this no longer happens?
This started to happen after I change the ECU.
antalus is offline   Reply With Quote
Old 11-15-2011, 01:44 PM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3633850
I've heard that Pep Boys has a device that plugs into the cigarette lighter to prevent a power loss to the ECU. Don't know what kind of auto parts stores you have in Guatemala, but you should check it out or buy online.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 11-15-2011, 01:47 PM   #3 (permalink)
seriously.
As the name of this device?
Old 11-15-2011, 04:40 PM   #4 (permalink)
ASE Certified Master Tech
View MasterTecInSTL's Photo Gallery
They also have ones that plug into the OBDII port but it does pretty much the same thing.
If an auxillary power point or the alternator stud is readily available I'll just install a jumper box there to keep it from losing memory while the battery is disconnected.
Of course this doesn't help if you're doing something that requires the system to be powered down - like airbag work or an "always on" circuit like a starter or alternator.
Usually a simple device like this one that holds a 9v battery and installs into your cigarette lighter will do the trick just keep in mind the battery won't last very long:
How often do you have to remove your battery?
MasterTecInSTL is offline   Reply With Quote
Old 11-15-2011, 05:19 PM   #5 (permalink)
you will have a photo or name of the device
I commented the following:
I can change the battery as long as the car is started.
The problem arises when I change the battery with the car off.
And I have to do this procedure http://www.google.com.gt/url?sa=t&rc...eqwdAg&cad=rja (page 13)
I would never, but sometimes necessary when changing any bad part, you know.
Old 11-16-2011, 12:49 PM   #6 (permalink)
View tarbasd's Photo Gallery
Why is it so terrible that the ECU resets?
'05 Corolla S, 4 cyl 1ZZ-FE (90000 miles)
tarbasd is offline   Reply With Quote
The Following User Says Thank You to tarbasd For This Useful Post:
antalus (11-16-2011)
Old 11-16-2011, 02:16 PM   #7 (permalink)
I don't know, i guess there are a problem betwen the key, immobilizer and ECU.
The scanner detected two Codes: P0630 Vin not programed o mistmatch and B2799 Engine immovilizer system malfunction
I guess those issues affect the ECU
But any mechanic can repair these codes
