Fog lights, how it works? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2011, 09:12 AM   #1 (permalink)
View antalus's Photo Gallery
Question Fog lights, how it works?
I have a corolla 2006, when i bought (1 year ago) the fog lighst no working, so i saw the box fuses and the ralay there was no.
So i bouhgt a new generic relay and fog lights new, but i have a problem, the fog lighsts its turn on all time, ( direct) the only way to turn them off is by removing the relay.
What happen?
the car have a interruptor hidden?
the relay is bad?
antalus is offline   Reply With Quote
Old 11-22-2011, 11:03 AM   #2 (permalink)
ASE Certified Master Tech
View MasterTecInSTL's Photo Gallery
Terminals 1 and 5 at the fog light relay have power all the time (from the 15amp FOG fuse).
Terminal 2 goes from the relay to the fog light switch to the Daytime Running Lights module. When this is grounded it engages the relay. In order for it to be grounded the DRL module has to apply a ground AND the fog switch has to be turned on.
Terminal 3 goes from the relay to the fog lights themselves. When the relay is activated it send power through this wire to make the foglights come on.
Since your relay was missing I have to assume that either someone was messing with the wiring and created a short to ground on the wire for terminal 2 and they had to remove the relay to make the lights go off.
Since turning off the fog light switch doesn't do anything then the short is going to be between the switch and the relay. You'll have to trace that red/yellow wire to find the problem or rebuilt the circuit.
MasterTecInSTL is offline   Reply With Quote
Old 11-22-2011, 11:14 AM   #3 (permalink)
My car don't have a switch for turn on/trun off
Old 11-22-2011, 12:01 PM   #4 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Where was your car made? Does it have a turn signal stalk with a switch on it for fogs? Or a button to the right of the steering wheel.
mikered30 is offline   Reply With Quote
Old 11-22-2011, 02:18 PM   #5 (permalink)
In Canada, for canada and USA market.
I can't found it the switch
Old 11-22-2011, 03:41 PM   #6 (permalink)
I'm wondering if someone put on a bumper with the foglights but they were not equipped from the factory. That would definitely explain why the relay was missing!
Maybe they jerry-rigged the wiring to make them come on...
Old 11-22-2011, 04:11 PM   #7 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $614831
View Zembonez's Photo Gallery
Without adding a switch, they are going to come on all the time.
Zembonez is offline   Reply With Quote
Old 11-22-2011, 08:54 PM   #8 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
So you don't see the dial on the rim of the indicator stalk on the left hand side of the steering then?
If your car was made in Canada and came with the fog lights then there is where it should be in 100% of the cases.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 11-23-2011, 12:48 AM   #9 (permalink)
Diehard Rams Fan
SuperchargedMR2's Avatar
Gameroom cash: $1341366
iTrader Score: 7 reviews
My 07 Corolla didn't come with fog lights. I bought a kit from eBay that included a switch for the dash where a blank is, all the wiring, relay & lights for less than $50.
ROTM November 2011 Winner!
SuperchargedMR2 is offline   Reply With Quote
Old 11-23-2011, 08:28 AM   #10 (permalink)
i found it, but not turn off the fogs lights
im thinking that relay is bad
Old 11-23-2011, 11:03 PM   #11 (permalink)
I've seen relays stuck on before. Is one of the other relays the same? You could try swapping them out and seeing what happens.
Old 11-24-2011, 06:53 AM   #12 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $152550
View hardtopte72's Photo Gallery
You should be able to swap the A/C Mag Clutch relay to test the operation. I have a ton of those Toyota relays that i pull from junkyards when I go.
You really need to post pictures of:
Your turn signal switch
Your fuse and relay center in the engine compartment
Your front bumper
hardtopte72 is offline   Reply With Quote
