Stereo Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2011, 10:30 PM   #1 (permalink)
View nick64cap's Photo Gallery
Stereo Problem
I have 05 corolla S. I installed new terminals on my battery the other day and when I connect the wires to the battery I accidentally put wrong cords on the wrong connections. Now my stereo wont power up. I checked all the fuses and they all seem in good condition.
nick64cap is offline   Reply With Quote
Old 11-26-2011, 11:59 PM   #2 (permalink)
ASE Certified Master Tech
View MasterTecInSTL's Photo Gallery
You probably fried your stereo then. Those things tend to happen when you hook the battery up wrong.
Just be glad you didn't fry your PCM.
MasterTecInSTL is offline   Reply With Quote
Old 11-28-2011, 11:08 AM   #3 (permalink)
The stereo is after market. Do you think the stereo itself might might a fuse that could have blown?
Old 11-28-2011, 11:20 AM   #4 (permalink)
Gameroom cash: $123850
View c_huynh32's Photo Gallery
The aftermarket stereos I've installed in my cars and helped a couple friends installed has fuses in the back of the unit.
But these were Sony and Pioneer. I am not sure which unit you have and if it has one or not.
c_huynh32 is offline   Reply With Quote
Old 11-28-2011, 02:00 PM   #5 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Better check all fuses and relays, you would be extremely lucky to have only blown your radio fuse. Does your car even start?
mikered30 is offline   Reply With Quote
Old 11-28-2011, 02:08 PM   #6 (permalink)
yes the car runs and everything seems to be running right but the stereo. I checked all fuses in the fuse box in the engine compartment and the one under the steering wheel. All the fuses appear to be in good condition. When I connected the wires to the battery and realized the connections were backwards I immediatly removed the wires. They only touched for a few seconds.
Old 11-28-2011, 05:11 PM   #7 (permalink)
I pulled the stereo to check it's fuse. The fuse seems to be in good condition. So what else could it be?
Old 11-28-2011, 05:22 PM   #8 (permalink)
Check if power is getting to the radio. if so then the radio is bad. Do you have the factory radio to plug in and test?
Old 11-29-2011, 03:34 PM   #9 (permalink)
no I do not have the stock radio to test it, but lets assume the radio isnt getting power. where would I go from there
Old 11-29-2011, 05:39 PM   #10 (permalink)
If you have power at the fuse but not at the radio then the wire between the two must have an open circuit.
Check the 15amp DOME fuse (also make sure there is power there)
Check the 15amp CIG fuse (again make sure there is power there)
Check the 30amp AMP fuse (if you have an AMP also make sure there is power there)
If you have power at these fuses and the fuses are good then the wiring is bad or the radio is bad.
Check for power at the radio's Blue/White wire and at it's Gray wire at the factory connector. If you have power at both wires the radio is fried.
Old 11-29-2011, 06:22 PM   #11 (permalink)
I checked all those fuses, they're all good. My head unit also has a fuse tho, and that one is in good condition.
Old 11-29-2011, 11:05 PM   #12 (permalink)
But are you getting power TO the fuses? And are you getting power at the wires I described at the factory radio connector? If so the radio is fried.
Would you rather me wave my magic wand and magically make your radio unfried?
