Whistling/squealing noise at idle 1k rpms In Park and Drive - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2011, 03:18 AM   #1 (permalink)
View cwest95129's Photo Gallery
i just replaced the belt tensioner replaced and the belt 20k miles ago they said it the belt was fine when replacing the belt tensioner . So it still has whistling squealing at idle 1000 rpms in park and in drive. the car is running fine it dosent seem to have any problems only when im stopped and in park and drive the noise comes out but nothing after im above 1mph and higher. the belt tensioner is from pepboys Dayco brand
cwest95129 is offline   Reply With Quote
Old 11-30-2011, 04:19 AM   #2 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
Originally Posted by cwest95129 View Post
i just replaced the belt tensioner replaced and the belt 20k miles ago they said it the belt was fine when replacing the belt tensioner.
You mean you replaced the belt 20k miles ago, and now you replaced the belt tensioner? What brand of belt is it?
... when im stopped and in park and drive the noise comes out but nothing after im above 1mph and higher. the belt tensioner is from pepboys Dayco brand
Can you tell if it is the belt when listening to it with your head under the hood?
invader is offline   Reply With Quote
Old 11-30-2011, 04:44 AM   #3 (permalink)
i dont know much about cars but the sound is coming from the belt tensioner area
im not sure what brand it is my mechanic replaced it becuase it was squealing then it went away and now its back even with the new tensioner the car is at 96k miles and this is my first one replaced i knew i should of gone to toyota but i was being cheap. i think my mechanic gose to toyota to get his parts but not to sure
will i have to worry about this noise or am i fine to drive. this is my daily driver
Old 11-30-2011, 07:02 AM   #4 (permalink)
The Dayco tensioner like I've had for a good while is fine... It's hard for me to tell what you're hearing, and only when idling at 1000 rpm. Can you get a sound clip of it from different spots around the engine?
Old 12-01-2011, 01:27 AM   #5 (permalink)
i can also hear it when i am sitting in the driver side when i open the door. when im in drive im at like 800 rpms and when i put it in park it gose to around 1000 rpm then drops to 800 rpm when it hits 1000rpm i can also hear a whistling sound coming from the driver side sounds like its coming from behind the air filter area and this is also when the car is warmed up and this is all in cold weather like around 45 Degrees i havent drove it in hot weather becuase its winter
Old 12-01-2011, 01:53 AM   #6 (permalink)
All stock intake? What year is that? It's an automatic? How's your transmission's fluid level, and was the fluid ever replaced? What mileage are you at?
Old 12-01-2011, 02:01 AM   #7 (permalink)
the mileage is at 96k miles its automatic its a 2007 S model i did a tune-up at 90k basic one its a stock intake im not sure if he replaced it but ill look later the fluid level is correct and the oil looks like its pinkish and redish as i took it to my mechanic and he said the transmission is fine
Old 12-02-2011, 02:03 AM   #8 (permalink)
View Balien's Photo Gallery
Canada
There is a tsb for transition cooling lines that rub on the transition making a hoot noise tsb #01205.
For my corolla it was the donut at the exhaust manifold you can easily go on the ground near driver door while noise is happening and touch the exhaust with your shoe. if it stops the sqeel/chirp noise get a new donut or possibly just change exhaust support straps. They changed three belts before they found it. Sounds exactly the same as a bad belt even when looking right at the belt.
Let me know if this is your problem too.
Balien is offline   Reply With Quote
Old 12-02-2011, 08:18 AM   #9 (permalink)
03' corolla 02' tundra
View alligatorgar's Photo Gallery
GO to a gator back belt from good year. Do a search on gator back belts in this forum and you will see a plethora of others with like issues.
http://www.goodyearep.com/productsdetail.aspx?id=3128
alligatorgar is offline   Reply With Quote
Old 12-02-2011, 10:37 AM   #10 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $152550
View hardtopte72's Photo Gallery
I own a 9th Gen and there are 3 Total in my family. I also worked for 3 years as a tech at Toyota. I have found there is no fix for the belt squeal on the Corolla. No matter which belt you use they squeal lightly on start up after about 10000 miles on a new belt and after 20000 miles the start up squeal gets louder. Mine squeals every morning. It can only be heard when outside the car. The belt tensioner is the updated kind I installed myself. The belt is almost new. I think the squealing comes when the felt that covers the rubber on the new belt wears off. The felt is softer and doesnt allow minor slips on the smooth pulleys. When the felt wears off the rubber slips ever so slightly on the smooth tensioner or water pump pulley when there is moisture or its cold. I consider it perfectly normal. If another manufacturer belt works better (I have seen plenty of different types squeal) then just use that one.
But...
I say get ready to deal with it. Just one of the few minor issues this car has (if you really consider it an issue).
On a good note I have never seen a 9th gen lose a belt. So the squealing isnt dangerous.
hardtopte72 is offline   Reply With Quote
Old 12-02-2011, 10:44 AM   #11 (permalink)
My GoodYear Gatorback serpentine belt is still always perfectly quiet with about 110,000 miles on it and Dayco tensioner, and it still looks great.
Old 12-02-2011, 11:39 AM   #12 (permalink)
ASE Certified Master Tech
View MasterTecInSTL's Photo Gallery
My 2003 has had a new tensioner and a "Continental" brand belt on for over 18 months (and 22,000 miles) and it's still completely quiet.
I love these belts.. they feel more solid and heavier than Gates/Dayco and have a textured "smooth" side which really help with noise issues. Their only drawback is they can be a little bit harder to install because of that but a little bit of water works as a lubricant to help it on.
I never was a big fan of the "gatorback" belts. All the ones I've seen with any kind of miles tend to stretch out much faster than others. Maybe not much of an issue if your tensioner has plenty of travel (like on these Corollas) but for cars with manually adjusted belts they can be problematic.
MasterTecInSTL is offline   Reply With Quote
Old 12-03-2011, 02:22 AM   #13 (permalink)
But...
yeah i can only hear the squealing from outside when i open the doors when im inside i hear nothing. so this shouldnt be a issue? my car seems to be running fine
Old 12-03-2011, 08:32 AM   #14 (permalink)
Toyota Fanatic
Yup. Like I said working at a Dealership regardless of what belt somebody had on their Corolla if the car was ever left over night it would squeal on cold startup or during humid nights. Mind does this everyday with only like 15K on the new belt. So does my brother in laws 03 with updated tensioner and my father in laws 07 with updated tensioner.
If another belt works then go for it. If your belt has no cracks and the noise isn't a rattling or grinding and you can't hear it from the inside just I wouldn't worry about it.
Old 12-03-2011, 12:50 PM   #15 (permalink)
Unless the noise is driving you absolutely bonkers! HA! The old belt was original and had no cracks but squealed its rear end off when cold or humid. I was well aware of the bulletin on the tensioner but I went ahead and replaced the tensioner and the belt together.
Never had any noise since - even on cold or humid mornings.
