Spark plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2011, 01:58 PM   #1 (permalink)
View joker96's Photo Gallery
Spark plugs
hi, am new here nice site lots of info, anyway wich spark plugs are the best for my 04 corolla? it just hit 115k miles and its vibrating a bit and since i have replaced those since 40k miles am replacing them now. am replacing sparks and wires. any ideas on wich are the best?
joker96 is offline   Reply With Quote
Old 12-07-2011, 04:26 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
NGK or denso iridium plugs.
mikered30 is offline   Reply With Quote
Old 12-08-2011, 01:36 AM   #3 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
There are no spark plug wires to replace. You have 4 coil-over-plugs.
Originally Posted by invader View Post
My NGK iridium BKR5EIX-11 (5464) plugs (φ 0.6 mm iridium alloy center electrode) were good for the 90000 miles that I used them, although the ground electrodes had worn down enough to increase gap from 1.1 to about 1.25 mm... My actual Bosch Platinum-Ir Fusion plugs are running exeptionally well. Its four yttrium-enhanced ground electrode design with exclusive surface air gap firing technology produce a longer, more powerful spark. They outperform OE iridium plugs by significantly reducing gap wear. Voltage requirement increases less over time than other iridium plugs. This results in less stress on the ignition system for quicker starts, more efficient fuel combustion, and a longer performance life.
http://www.boschautoparts.com/sparkp...mIrFusion.aspx
Original standard plugs are Denso's Iridium Long-Life SK16R11 (φ 0.7 mm iridium alloy center electrode) with platinum coated ground electrode.
You can upgrade to Denso Iridium Power IK16 (φ 0.4 mm iridium alloy center electrode) with taper-cut U-groove ground electrode, or Denso Iridium Tough VK16 from Japan (φ 0.4 mm iridium alloy center electrode) with platinum tipped ground electrode. Quality is a bit better than NGK... They're all pre-gapped to 1.1 mm (0.0433"), as required.
http://www.globaldenso.com/en/produc...structure.html
http://en.item.rakuten.com/ap-murase/v91105603c/
invader is offline   Reply With Quote
Old 12-15-2011, 03:28 PM   #4 (permalink)
View TRDRadRedTaco's Photo Gallery
Would you happen to know which Bosch Platinum Ir plug fits my 2008 Matrix, or could you point me to a site that I can find this out? I see 4501, 4504, 4505, 4508, etc listed for sale, but nothing telling me which one fits what. Thanks
TRDRadRedTaco is offline   Reply With Quote
Old 12-15-2011, 06:24 PM   #5 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $1001064
View humanoid's Photo Gallery
I would advise you not to use Bosch plugs because from my experience, if you use any plugs any other than NGK or Denso, it'll make your car run like crap.
This is my sig.
humanoid is offline   Reply With Quote
The Following User Says Thank You to humanoid For This Useful Post:
TRDRadRedTaco (12-16-2011)
Old 12-15-2011, 09:19 PM   #6 (permalink)
Bosch Platinum IR Fusion FGR8DQI (# 4501)... Best dang spark plugs I ever used.
I did however get Denso oxygen sensors.
The Following User Says Thank You to invader For This Useful Post:
Old 12-22-2011, 05:47 PM   #7 (permalink)
View endofmankind's Photo Gallery
is use E3 spark plugs on all my cars (including my 03 corolla) and truck.
my corolla run real smooth and has a great pick up. when I changed my plugs I also clean the trottle body and change the air filter. I didn't care much for the NGKs and stay away from Bosch.
endofmankind is offline   Reply With Quote
Old 12-22-2011, 10:40 PM   #8 (permalink)
E3 are cheap Chinese plugs and are not worth it. They tend to foul out from carbon tracking, or melt down causing engine damage. Avoid them like the plague, and stick to quality iridium spark plugs as recommended.
You can always trust genuine Denso, Bosch or NGK spark plugs.
