Thanks for your reply. Actually I released the 2 hold-down clips you described on the front top side of the air cleaner box, but the hose, or a round tube of some kind, that is attached to the firewall side of the lid won't let it be raised more than 2 or 3 inches, which isn't enough clearance to allow it to fold back on the plastic hinges at the rear of the box. I don't want to start disconnecting tubes or anything else that I don't know anything about, and I hve no idea what that attached item that appears to be a black rubber tube does. Did you have that same situation with raising the top lid? If so, how did you get around it, by taking off the attached tube(s)? If so how did you remove it? I tried gently pulling on it but it wouldn't budge, and don't want to mess something up by forcing it open by prying with a big screwdriver.
Thanks again, and if you have more info or if I misunderstood your directions, I would appreciate hearing more from you. If I can't get it right myself I guess I'll take it to a local independent tune-up shop I sometimes use for minor jobs and see if he can install it at a reasonable price. He recently installed new headlight bulbs in an Altima of mine for $20 labor and I supplied the bulbs. I don't know how auto repair prices run in your area, but around here NOBODY else would even bother to open up a hood for $20.
