Car shorts on startup?
Hey folks,
I'm new to the board as this is my wife's car but I'm hoping you can help. My wife's battery had discharged several times before I replaced it and then as I was driving down the road with her a month back I found her lights would dim and sometimes the car itself seemed to "reset" at stops or when current draw increased(high beams, heat blower on, etc..) so I tested the alternator and it turned out to be bad so I replaced it two weeks back.
After replacing we ran into a situation where when she stuck the key in the car would chime, when we turned to "Acc" everything would power on, "On" would light the dash up and "Ign" would kill everything. I believe this is the pattern although it may also happen when turned to "On" as well. I thought it was the ignition switch so I tested the switch when it was functional and it test good. I disconnected the ignition harness and jumped the car from the harness and it worked the first time. The second time it did the same thing upon connecting 12v to the ignition. Right after I did this I decided to start test voltage on the harness. Now the harness was showing 2 to 3 volts instead of 12.7.
I jumped under the hood and test the battery, 12.7 volts. I test the terminals beyond the battery 12.7 volts and then I test the fuses at the main housing and they all test 2-3volts. What's odd is if you wait a few minutes all this resets back to 12 volts and sometimes it starts right up and sometimes it starts the cycle again. Also I disconnected what I believe is the main connection into the fuse box, when connected it was measuring 3 volts, when I disconnected it the cable from the fuse box it measured 12.7 volts. I am thinking starter or starter solenoid but honestly I don't know enough to test those or even know where they are on her car. I replaced the alternator in the dark and I guess I could do a starter but I don't want to throw more money into that until I figure it out.
