check engine light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-13-2011, 08:29 PM   #1 (permalink)
View ebikok's Photo Gallery
Unhappy check engine light
i installed a codl air intake powerflow to my corolla 2003 vvti 16 valve 1.8 automatic, after 1 hour running the check engine light turn on, i disconnected de battery and it went off but after driving a couple of hour it turn on again, i also have a DC header 4-1
Can anyone help me whats wrong?
ebikok is offline   Reply With Quote
Old 12-13-2011, 08:52 PM   #2 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291852
View gold94corolla's Photo Gallery
Did you mess up the intake sensors? They have to be positioned correctly. Or, the increased airflow causes the sensor to have out-of-range readings, and put a CEL. You'll have to live with the CEL in this case. On my IS300, the intake required a ECU mod chip to fix this problem.
gold94corolla is offline   Reply With Quote
Old 12-13-2011, 09:57 PM   #3 (permalink)
ASE Certified Master Tech
View MasterTecInSTL's Photo Gallery
I never found these things to be worth it.. just put the stock box back on and be done with it.
Of course the light could be completely coincidental as well. Stranger things have happened. If you want to get it scanned and let us know what the codes are we can take things from there.
MasterTecInSTL is offline   Reply With Quote
Old 12-13-2011, 09:59 PM   #4 (permalink)
The sensor is good.
Whats a CEL where can i get one online?
Old 12-13-2011, 10:13 PM   #5 (permalink)
Corolla NEWB
View dojaman's Photo Gallery
CEL means check engine light. Let me see your Vac lines, i just went through this. What is your engine code? How is your idle?
dojaman is offline   Reply With Quote
Old 12-13-2011, 10:14 PM   #6 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $152550
View hardtopte72's Photo Gallery
CEL= Check engine light you do not want one lol.
You are going to have to take the car to get scanned somewhere. It could be a check engine light for a transmission solenoid, a lean condition, or an ECU error. There is no way of diagnosing it without a code.
hardtopte72 is offline   Reply With Quote
Old 12-13-2011, 10:15 PM   #7 (permalink)
Corolla NEWB
Auto zone and oreillys do it for free in hopes you will buy the parts there. If you own a car, its worth buying a scanner.
http://www.obdcom.com/?gclid=COjU1ajagK0CFUmR7Qod9XloSw
That one datalogs, and they sell bluetooth ones to use with smartphones. Google search obd Kiwi.
http://www.plxkiwi.com/
Old 12-13-2011, 10:37 PM   #8 (permalink)
Toyota Fanatic
OP is in the Dominican Republic. I think you will be hard pressed find Autozone there lol.
OP also does not say any other symptoms.
Old 12-13-2011, 11:31 PM   #9 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
How many Kms on it, and have your replaced your intake manifold gasket for Toyota's new revised one? Cleaning your Mass Air Flow/Intake Air Temperature sensor (screwed onto your intake aluminum tube) can also help.
A good mechanic should have a 'CAN' code reader to read your trouble code (CEL), or you can order one:
http://www.aliexpress.com/product-fm...olesalers.html
http://www.aliexpress.com/product-gs...olesalers.html
Code reader interface (Used with a laptop computer):
invader is offline   Reply With Quote
Old 12-14-2011, 04:59 AM   #10 (permalink)
I just cleaned the air sensor and its ok...
Its not thw intake manifold but i will check out and no i havent changed to the new one..
I will get it scan today and reply to all
Old 12-14-2011, 05:15 AM   #11 (permalink)
am on it
Old 12-14-2011, 04:07 PM   #12 (permalink)
View Crashlee's Photo Gallery
Well that solution failed. My cel came back on this morning, the solution would have never worked lol. Sorry. Hopefully we can both find a solution to this annoying problem!
Crashlee is offline   Reply With Quote
Old 12-14-2011, 04:27 PM   #13 (permalink)
You should consider starting your own thread for your problem and not hijacking the original poster's thread. It becomes very confusing for a lot of people.
Old 12-14-2011, 05:49 PM   #14 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $1001064
View humanoid's Photo Gallery
Everyone needs to calm the hell down or infractions and/or temp bans will be handed down, thanks for your cooperation.
This is my sig.
humanoid is offline   Reply With Quote
Old 12-18-2011, 09:13 PM   #15 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3633850
Please, only replies to help the OP from this point forward. Thank you.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
