Question about having 04 Corolla clutch replaced.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2011, 11:59 AM   #1 (permalink)
View Jimigunne's Photo Gallery
Does anyone know what the estimated man-hours is for the 5-speed transaxle clutch replacement. I know I am going to have to have the clutch replaced soon, its starting to slip for just a second when you bump the accelerator a bit too hard when cruising at 65 in 5th gear. I don't have a clue if this is a job that is going to set me back $1000.00 or 2000.00. But it looks like a multi-day job even for a pro, looking at this in the Haynes manual. If I knew about how many hours of shop labor it takes, I could get an idea of what a reasonable price for the job is.
Jimigunne is offline   Reply With Quote
Old 12-14-2011, 01:39 PM   #2 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
From what I remember, Toyota said replacing a clutch requires the entire transmission to be taken out so it could be a 4 - 6 hour job.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 12-14-2011, 02:44 PM   #3 (permalink)
ASE Certified Master Tech
View MasterTecInSTL's Photo Gallery
Labor is 8.4 hours so you're looking at about $800-1000 in labor depending on the labor rate of the shop that does the repair.
Take it to a shop that specializes in transmission repairs. They'll give you a break on labor since they do this all the time and are very fast at it. Make sure you get several estimates and compare prices AND warranties. Also take a few minutes to talk with the guys at each shop and make sure you're comfortable with them. I don't care how inexpensive somewhere is.. If they don't know their your car from a hole in the ground I wouldn't trust them.
Sometimes it's fun to play dumb just to see how they treat you!
MasterTecInSTL is offline   Reply With Quote
Old 12-16-2011, 10:08 AM   #4 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $152550
View hardtopte72's Photo Gallery
This is one of the easiest FWD transmissions I have ever removed. The hardest part is the rear trans mount and remembering where to put tr grounds. If you are not willing to tackle it then maybe consider a friend who works on cars or like stated before a shop that does transmission repair a lot.
hardtopte72 is offline   Reply With Quote
