Exchanging ECM's
I have a 2003 Corolla S, 5MT with the dreaded P0420 error code that I can't get rid of. The dealer tells me the ECM in the car is either 89666-02133 or 89661-02080 by the VIN.
Since I don't want to risk the dealer bricking it by reflashing and being out the cost for the flash and a new ECM. I want to know if one from an 05 or 06 5MT will work with out flashing to get the higher rev level firmware.
Is it worth looking at any 2004 ECM's since the TSB EG028-04 includes 04 models?
I found that the 2005 5MT had the following ECM's: 89661-0Z041, 89661-0Z042, 89661-0Z043, 89661-02D11, 89661-02D12
I found that the 2006 5MT had the following ECM's: 89661-02D01, 89661-02D02, 89661-0K20, 89661-02C13
Does anyone know what the difference between them is? Are they interchangeable since neither years came with an immobilizer? The dealer told me the immobilizer came on the 07 model.
I am trying to avoid paying for a new cat if the problem is the tolerances on the 2 sensors around the cat. I have found TSB EG028-04 that advises a reflash but indicates that a certain ECM may be bricked by the process. I have read that the earlier ECM's had a tighter tolerance between the 2 sensors and the latter ones were looser eliminating the CEL that I need to get off to be emission tested.
thanks from a new member/lurker here...
