A couple of questions about the 9th generation 'rollas
I'm looking to buy a used 9th gen for the wife. She was in a wreck the other day and her old vehicle is no more. She wasn't hurt thankfully, but now she needs a different vehicle.
So the 9th gen Corollas are falling within her budget and I've found 3 for her to look at, all of them manual trannys.
Is there a factory service manual available for download anywhere? We've had a couple of Hondas over the years and I managed to find the actual Honda service manual (about 2500 pages) available for download. I'd prefer this instead of Haynes/Chilton.
One of the Corollas (an LE) I'm having her look at appears to have been neglected on maintenance, specifically oil change intervals. Of course the dealer put in fresh oil, but I could easily tell the previous owners didn't keep up with because of the black gunk found around the drain plug, and then of course I noticed inside the fill port that inside there was some sludge buildup. I'd love to get my hands on that thing for about a hour to take the valve cover and really see it what it looks like in there, but I just don't know. I suppose if I went with this one, I would drown it in Seafoam then fill it with synthetic to try and clean it out more. The point is I'm just not sure how much torture this engine can take. To the best of my knowledge, there's nothing specifically wrong with the engine building up sludge or anything similar...can anyone confirm this?
The other 2 Corollas (both CE) did not exhibit the poor oil maintenance the first one did, however one took a bit to start. That could be either bad battery, maybe the fuel pump, clogged injectors...who knows. Both vehicles exhibited a slight, yet noticeable vibration when I idled the engine to around 2500...is this normal?
All vehicles seem to need their clutch replaced within about 30k miles or so.
So to summarize...
2005 LE, 87k miles, asking $7700. Has the sludge problem
2006 CE, 112k miles, asking $7900. The normal wear and tear best I can tell...had the vibration I mentioned above.
2006 CE, 74k miles, asking $7900. Took a bit to start, vibration.
Any thoughts or suggestions?
