excessive vibration at idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2011, 11:20 AM   #1 (permalink)
View gingn's Photo Gallery
I have a 2003 Toyota Corolla le with 111,111 miles on it and it has an excessive vibration at idle in all gears. You can feel it in the seat and the steering wheel in the cabin. There is no mil, and all of the engine mounts are good. It goes away when you start to accelerate. I have recently replaced the spark plugs, engine oil and filter, PCV valve, serpentine belt tensioner, and am just at a loss with this vibration at idle. ANY ideas??
Last edited by gingn; 12-20-2011 at 11:25 AM. Reason: didnt like title and wanted to change it so more people will understand problem
gingn is offline   Reply With Quote
Old 12-20-2011, 11:50 AM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Clean the throttle body and idle air control valve.
mikered30 is offline   Reply With Quote
Old 12-20-2011, 12:47 PM   #3 (permalink)
Is that a common problem for the corollas?
Old 12-20-2011, 05:15 PM   #4 (permalink)
mikered30's Avatar
http://matrixowners.com/index.php?/t...idepics-incld/
You can clean the TB and IACV while still attached to the engine.
Carbon/dirt build up is common on all gas engines, not just the corolla.
Old 12-21-2011, 09:34 AM   #5 (permalink)
View dorman68's Photo Gallery
The 1ZZFE engine was never a smooth idling engine when it comes to vibration. These engines do not use a balance shaft like the 2.4 Camry engines do. Some vibration should be expected, anything excessive I would look to blame the engine mounts. Hope this helps.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is online now   Reply With Quote
Old 12-21-2011, 02:03 PM   #6 (permalink)
Cleaned TB and AICV and i noticed that there was a oil in my intake manifold. What would cause this?
Old 12-21-2011, 06:29 PM   #7 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
The 2ZZ-GE does not vibrate or shall I say it vibrates much less than the 1ZZ.
However, that is primarily because of a slightly higher idle speed. My 2ZZ-GE idles at 1000 - 1100 rpm when thoroughly warm compared to 700 rpm for the 1ZZ-FE.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
