problem with corolla 2003
hi guys,
i have a little problem with the toyota corolla 2003 and is that when im running and press the brake the rpm drop down to 600 and the vehicule vibrates, the mechanic has cleaned the throttle body and the filters, cleaned the iac valve, new spark plugs, and the problem persists.
the iac valve was cleaned without disconnecting the connector, we disconnected it and the car improved but the rpm still drop
when im in reverse normally the rpm drop more, we resetted the ecu and the problem improved some days but the problem came back.
in the only occasion that the car improved was when we disconnected the iac valve and the screws and there it improved some days but still the same thing but less intense.
also i notice when im stopped in the vehicule the rpms increase a little, mechanic checked and no leaking, the mechanic also cleaned inyectors, checked coils, changed filters.
I have noticed as well that when i accelerate it fast the car it pulls a little bit and when you go in U turn i feel the car heavy.
what could be the problem, replacing the iac valve??????
