Help corolla 2004!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2011, 12:07 PM   #1 (permalink)
View flash2563's Photo Gallery
Help corolla 2004!!
hi friend, as they are, I have a question but also a small problem in my car and that is when accelerating and vece noticed that the throttle is slow to respond, and been looking at various car photo internet friend and noticed that e my body has two cable acceleration and speed of my friends have one, then I would like to know is this normal or was that put him in my car, because everything and has seen only a single cable and mine has two Please leave me doubt like a photo attached thank you very much
http://imageshack.us/photo/my-images...ith2cable.jpg/
flash2563 is offline   Reply With Quote
Old 12-28-2011, 11:36 PM   #2 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
The second one with the slot is for your cruise control.
invader is offline   Reply With Quote
Old 12-29-2011, 05:57 AM   #3 (permalink)
Thanx friends
Old 12-29-2011, 07:26 AM   #4 (permalink)
View z27ls3's Photo Gallery
clean the throttle body pictured.
"I have a question but also a small problem in my car and that is when accelerating and vece noticed that the throttle is slow to respond"
I would start with a spray can of throttle body cleaner, just remove the intake boot, hold the throttle body open and saturate the interior with the cleaner. let it soak 5 min & clean with a toothbrush and shop rag. it probably has carbon buildup on the inside and is making the throttle action sluggish. its a $5.00 service if you have to buy the cleaner.
how are the spark plugs? using NGK or Denso ?
z27ls3 is offline   Reply With Quote
Old 12-29-2011, 04:48 PM   #5 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
Are you saying it used to be quicker, but recently became slower??? Or you never experienced any quicker response? ?
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 01-01-2012, 10:28 AM   #6 (permalink)
View ersa's Photo Gallery
reply
since ive purchased the car in september ive been feeling it like this, in high acceleration it feels fine its in low.
One question also, what maintains rpms stable? is it sensor or is it the throttle that helps?
ersa is offline   Reply With Quote
Old 01-01-2012, 05:05 PM   #7 (permalink)
Your original intake manifold gasket is probably leaking and affecting idle stability. Replace with Toyota's revised gasket.
