Originally Posted by empirefalls
120,000 miles
Occasionally I am hearing a sound when starting up on cold mornings, a very sharp spinning metalic sound. Maybe once every 2 months--could be more but i dont hear it.
I am thinking of changing the Starter even if it not the starter, just to have a fresh Starter in my vehicle. So far it looks like a starter is not that exspensive and rather easy to exchange.
Back in high school on a completely different car I experienced this. It turned out to be bad teeth on the flywheel. I don't know if that's caused by the starter not being aligned properly or what, but if that's your problem it is only a matter of time before you won't be able to get it to start at all. I suppose it might be possible that the starter is turning w/o engaging the flywheel at all, in which case you could just replace the starter, but I dunno if you'd hear the starter turning if it wasn't making mechanical contact with anything.
It should be easy to determine the extent of the damage, though. Take your old starter out and have it bench tested. Before you put it back in, have a friend slowly turn the engine with a wrench on the bolt coming out of the crankshaft pulley while you examine the flywheel teeth.
If the flywheel has been damaged you're probably not going to make the problem more expensive to replace by waiting, except that you'll eventually need to get it towed (unless your car is a stick shift and you can push start it). The flywheel replacement would cost several hundred dollars, I'd bet as they'll have to take the transmission out to do it, and that's probably a good time to replace the starter anyway. Hopefully your starter is just not engaging as that's a lot cheaper.
I just changed the starter on my car yesterday and it was an easy 2 hr or less job. Toyota dealer wanted $400 for the starter but I got one from Advance Auto for $98 (closest place as I had to bike to get there).
I did not have to take the battery or airbox out, but I have a stick shift in my '03 Corolla so that might have made it a little different than what others have posted.
