Help a girl out - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2012, 02:19 PM   #1 (permalink)
View CamoSamurai's Photo Gallery
Help a girl out
Hi! I am trying to help my stubborn husband out here. Our wonderful, usually dependable 2008 corolla started giving us issues today. Check engine light popped on, it's idling rough at times and then kinda sputters out and doesn't respond to the gas pedal. Kind of odd.. husband said it made a click noise but I didn't witness that in the time I was watching it idle. It was remaining around 1,000 rpms while sitting in our driveway.. however it seems to dip down when it starts going rough.
We first thought maybe bad fuel so we put extra fuel into the tank. We let it run and revved the engine some to move the new fuel around. This is our daily use car so it wouldn't have an issue with old gas or anything like that.. we actually just fueled up on.. tuesday or wednesday, so there was still some fuel in the tank. errm.. trying to think of what else.
I did go out and write down the VIN to lookup on the toyota website. It has a recall supposedly, but keep in mind I am very new to knowing anything about cars. I don't know if this could be our problem or not. Would it cause the rough idle and lack of responsiveness from the pedal? No worries I will push the car to a mechanic myself if I have to, I'd just like to mentally prepare myself for the potential issues.
-- I think I covered all the issues it's presenting.
CamoSamurai is offline   Reply With Quote
Old 01-01-2012, 02:27 PM   #2 (permalink)
View onemph05's Photo Gallery
Bring it to the dealership and its probably the ECM recall. Its simply the computer brain of the car and they had a bad batch.
onemph05 is offline   Reply With Quote
Old 01-01-2012, 02:45 PM   #3 (permalink)
Awesome! Thanks, that makes me feel 100 times better. We're taking tomorrow morning to get repaired. All the dealerships are closed today it seems.
Old 01-01-2012, 05:41 PM   #4 (permalink)
mikered30's Avatar
Gameroom cash: $532567
You should have gotten a recall notice early last year for this issue. Sounds like the ECU is the issue.
mikered30 is offline   Reply With Quote
Old 01-01-2012, 05:51 PM   #5 (permalink)
View johnoh's Photo Gallery
I wouldn't make any assumptions at this point. If you go to autozone they will tell you for free what the check engine code was (even if it the check engine light is not currently on). Takes 5 minutes. The code will be in the form of Pxxxx . Post that code here and people can comment on what causes that code for your corolla.
johnoh is offline   Reply With Quote
Old 01-02-2012, 07:37 AM   #6 (permalink)
View jmazz77's Photo Gallery
+1 How can anyone assume it is the ECU without knowing what code set off the CEL?
jmazz77 is offline   Reply With Quote
Old 01-02-2012, 02:44 PM   #7 (permalink)
View NWCorolla05's Photo Gallery
Proceed on both tracks: get the code on the CEL and if you haven't yet had the ECU replaced, make time for that.
NWCorolla05 is offline   Reply With Quote
The Following User Says Thank You to NWCorolla05 For This Useful Post:
jmazz77 (01-02-2012)
Old 01-04-2012, 08:06 AM   #8 (permalink)
View i4getlots's Photo Gallery
do you guys keep up with maintenance? meaning oil changes, changing the air filter, fuel filter and spark plugs?
i4getlots is offline   Reply With Quote
