I would check a couple other cars' tailpipes to make a comparison. Soot in the exhaust is to be expected, as is water from condensation, so they can mix and look like sludge. All cars run rich while cold, which is worse in the winter, and condensation is worse in the winter as well. Your sig shows you to be in cold/damp england, which compounds the issue. That's why I say to check some other cars to compare. The real question is do you have other symptoms such as poor mpg, a check engine code, or does the car consume oil. Don't forget to check/change your air filter and pcv valve regularly - true for all of us but sometimes neglected.
