hid's questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-08-2012, 08:23 PM   #1 (permalink)
View camaro98's Photo Gallery
hid's questions
i just bought hid's for my 03 corolla.i know the DRL is only 7 volts(causes hid to flicker) and hid's need 12 volts.so i don't know how to disable my DRL.i could make my own harness and put toggle switch.so what is the best way to put hid's on this car.
camaro98 is offline   Reply With Quote
Old 01-09-2012, 07:39 AM   #2 (permalink)
Gameroom cash: $113400
View ThetaMike888's Photo Gallery
Most people just disable their DRLs. If you look under the steering column and you'll see a black box with a wiring harness connected to it. Locate pin 12 (small red and white wire immediately next to the 2 larger wires). Cut that wire. Some people put a switch in between to "turn back on" the DRL functionality but i personally dont care for it. You will lose your "auto lights on" function too FYI.
ThetaMike888 is offline   Reply With Quote
Old 01-09-2012, 06:56 PM   #3 (permalink)
well i read the hid's i got they are some cheap ebay lights .and i decided not to put them on.i really dont want to get ticket over hid''s.but thanks anyways
Old 01-10-2012, 12:28 PM   #4 (permalink)
ASE Certified Master Tech
View MasterTecInSTL's Photo Gallery
Yeah if you're simply replacing the halogen bulbs with HID bulbs then you're just asking for trouble. The right thing to do would be to install HID projectors as well. I think I saw someone here that modified their halogen projectors to work properly with HIDs.
MasterTecInSTL is offline   Reply With Quote
