2006 Toyota Corolla S belt noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-10-2012, 12:23 PM   #1 (permalink)
B.Rolla
View bryan06rolla's Photo Gallery
Hey guys, I have aN 06 corolla around 73,000m on it. For a couple months now my belt(around that area) has been making a really screechy sound whenever I turn it on. It goes away after being on for awhile though. Is there something I can do to fix this? If it's serious that is
bryan06rolla is offline   Reply With Quote
Old 01-10-2012, 12:26 PM   #2 (permalink)
ASE Certified Master Tech
View MasterTecInSTL's Photo Gallery
It probably just needs a belt and a tensioner. These tensioners are known to be problematic in a way that allows the belt to make a lot of noise especially when cold.
Also make sure the water pump hasn't been leaking - even a tiny tiny bit of antifreeze can cause your belt to throw a fit!
If you're good at all with tools you can probably do this work yourself.
MasterTecInSTL is offline   Reply With Quote
The Following User Says Thank You to MasterTecInSTL For This Useful Post:
bryan06rolla (01-31-2012)
Old 01-10-2012, 07:47 PM   #3 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
That's a very common problem with Toyota's original serpentine belt. They all do that before long. All you need is a quiet and long-lasting GoodYear Gatorback serpentine belt # 4060740. Problem solved... There is most likely nothing wrong with your 2006 belt tensioner.
invader is offline   Reply With Quote
The Following User Says Thank You to invader For This Useful Post:
