Issues with Cruise control on '05 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2012, 02:13 AM   #1 (permalink)
View Charleymoo's Photo Gallery
Question Issues with Cruise control on '05 Corolla
Hello all!
I have recently(within 2 months) bought this Corolla that I LOVE, but the cruise control is quite flaky! The light will come on, but it doesn't like to set very easy.. I HAVE gotten it to work several times, but it takes a lot of tries and sometimes won't even set at all.. Its all been on the freeway(60 - 80mph), nothing special.. however, it is a Manual transmission, but i wouldn't think that would make much of a difference. let me know if i should be doing anything in particular that i'm not! thanks so much!
CharleyMoo
Charleymoo is offline   Reply With Quote
Old 01-12-2012, 12:19 PM   #2 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
So you do push the stick down to engage the cruise control. Right?? Are you saying you push the stick down and it does not engage?
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 01-12-2012, 12:29 PM   #3 (permalink)
Indeed i do.. haha the light comes on, i tap it down, it just doesn't like to set/keep speed. It does set sometimes, just about 10% of the time.. it almost seems like chance whether or not it will hahah
Old 01-12-2012, 01:04 PM   #4 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $152550
View hardtopte72's Photo Gallery
Could be any number of bad switches (clutch,brake,cruise control) or a bad ECU. It would probably be best to take it to the dealer.
My Toyota list:
1982 Corolla SR-5 Hardtop 5 Speed Manual(R154) 1JZGTE
2005 Corolla CE 5 Speed Manual 1ZZFE
2009 Camry LE 5 Speed Auto 2AZFE
If I helped out in anyway please hit the thanks button on my post .
hardtopte72 is offline   Reply With Quote
Old 01-12-2012, 04:44 PM   #5 (permalink)
MD1032's Avatar
View MD1032's Photo Gallery
You're not trying to push the button and "set" the speed at the same time, are you? The button is just a switch. You can really just leave it on all the time (if the green "cruise" light wasn't so annoying, that is). I find that with mine, you have to kind of hold it down for half a second for it to register.
MD1032 is offline   Reply With Quote
Old 01-13-2012, 01:45 AM   #6 (permalink)
no, I was doing them separately.. haha I actually found on another post on here about someones manual not setting speed on cruise control if there was ANY pressure at all on clutch. Even if their foot was just resting on it. They suggested puting their foot behind the clutch and pulling back very slightly just to make sure. Even though it wasn't a solution to their problem in that post, I thought I'd try it out. I think my foot may have been resting on the clutch the other times I was attempting to engage cruise, so I think that was the culprit. when I tried it again tonight on my way home from work I pulled up from behind the clutch with my foot just a tiny bit and sure enough, the cruise control set the speed without any trouble at all! I even disengaged it and tried it again just to make sure. So thanks again everyone for your tips! and sorry I didn't look hard enough for past posts about the same problem :b thanks a ton though!
CharleyMoo
Old 01-13-2012, 08:50 AM   #7 (permalink)
MD1032's Avatar
If you make it a habit of resting your foot on the clutch, start training yourself to not do that. Especially with these Corollas, it's easy to partially disengage the clutch without noticing...you will wear out your clutch significantly faster by resting your foot on it. There is a plastic block to the left of the clutch pedal where you can rest your foot while not shifting. It is farther forward than the clutch pedal and more comfortable anyway.
On any car I have ever driven, the clutch and the gas pedal both cancel cruise control. On my drive by wire Corolla, only the clutch does. They also give you a cancel button on this car. Instead of pressing the button on the cruise control wand, you can pull the cruise control wand towards yourself to cancel the cruise.
The Following User Says Thank You to MD1032 For This Useful Post:
Charleymoo (01-13-2012)
