Climate Control Lighting/ Shifter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2012, 06:45 AM   #1 (permalink)
View apollonius's Photo Gallery
Did a search in this section and saw a few reports of people with the same issue but no suggested fixes.
Basically 2/3 lights on my climate control work 100% of the time while the 3rd will sometimes come on if I adjust the knob back and forth a few times.
Shifter lights are usually off 80% of the time although they randomly will start working on longer drives or on a different start up.
Any suggestions? Can the dimmer toggle cause issues like these or should I look somewhere else?
apollonius is offline   Reply With Quote
Old 01-13-2012, 07:58 AM   #2 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291852
View gold94corolla's Photo Gallery
It's just loose bulbs. You can remove the bulbs, then bend the contact wires out some, and reinsert to give a better contact. Either that, or the bulbs are nearly burned out.
gold94corolla is offline   Reply With Quote
Old 01-13-2012, 08:02 AM   #3 (permalink)
Seems odd but I will try that. I have pulled them out and put them back in but did not try bending the contacts out. This problem started Basically as soon as I bought the car just never bothered to get it fixed since the dealerships option was replacing the entire climate control unit... lol
