Need pics - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-19-2012, 05:11 PM   #1 (permalink)
04S
View 04S's Photo Gallery
Need pics
Hello everyone I'm new to this forum and I have a 2004 Corolls S that I am looking to lower. I wanted to go with the H&R Race Springs withTokico Blue Shocks. So my question is can anyone provide pictures of the S model with a 2inch drop so I can make a decision. I've seen the picture section of everyones ride but nobody gives any details on their setups.
04S is offline   Reply With Quote
Old 01-19-2012, 08:25 PM   #2 (permalink)
04S
wow no responses god i miss 9thgencorolla.com
Old 01-19-2012, 09:35 PM   #3 (permalink)
View ab30494's Photo Gallery
be more patient.
ab30494 is offline   Reply With Quote
Old 01-19-2012, 09:42 PM   #4 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
Someone will respond soon. I would post mine up, but I have an XRS (which stock is already 0.5 inch lower than other variants) so it will not give you an accurate idea:
Anyway, here they are since something is better than nothing. My drop is 2.0 inches at the front and around 1.8 inches on the back
My XRS on H&R race springs + 205/50/16 tires on stock 16 x6 wheels (very old back from circa 2006):
XRS on H&R race springs + 205/50/16 tires on Motegi lightweight 16 x 7 wheels:
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 01-20-2012, 08:23 AM   #5 (permalink)
04S
Thank you for the reply hopefully people with a S model will post pics so I can get an idea. Now I do have 2 questions: 1) will running the tokico shock help with getting a lowered height my understanding is that its shorter than stock 2) I plan on running 18" wheels will that help close the gap between tire and fender or make it worst
Old 01-20-2012, 10:26 PM   #6 (permalink)
Moderator
1 - I have never heard of that. If you research everywhere on the internet, you see usually ride height I believe is controlled by springs. I think if you put shorter shocks with stock springs, it will not reduce the ride height much. I might be wrong, but that is what I think will happen.
2 - If you use 18 inch wheels on stock springs, it will definitely cover the gap between the fender and tire a bit more. However, since the entire circumference of the 18 inches wheel with tires (even when factoring lowest profile tires) is more than the stock circumference, the ground clearance of the car will actually increase. In short, yes the gaps between the fender and tire will fill more, but the car will look like an SUV with a very tall ground clearance.
Old 01-20-2012, 11:20 PM   #7 (permalink)
04S
But even if I lower it its going to look like what you are saying.
Old 01-21-2012, 12:37 AM   #8 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $152550
View hardtopte72's Photo Gallery
The only reason you would need a shorter shock with lowering springs is if the springs lower the car so much that the stock shocks are so far out of their comfort zone they blow out. This is usually paired with a shorter strut housing as well. A lot of AE86 people have to do this with coilovers as any of the stock height shocks will blow so they cut the struts and run MR2 short stroke shocks and coilovers.
You really shouldn't have that problem unless the car is slammed big time.
My Toyota list:
1982 Corolla SR-5 Hardtop 5 Speed Manual(R154) 1JZGTE
2005 Corolla CE 5 Speed Manual 1ZZFE
2009 Camry LE 5 Speed Auto 2AZFE
If I helped out in anyway please hit the thanks button on my post .
hardtopte72 is offline   Reply With Quote
Old 01-21-2012, 01:20 AM   #9 (permalink)
Moderator
No if you lower the car, it will reduce the ride height of the car. Remember a larger circumference wheel/tire will fill only a part of the gap and not all. Once lowering springs are used, it will lower th body and bring it closer to the ground.
You really should understand the difference between the two measures.
