Hello all, I'm in a need of some help..... not very car savy here. I noticed oil leaking, at first I thought it was the seal on the oil pan, so I replaced the gasket and oil filter.
After wiping everything clean, seems that the leak is above the oil filter, where the oil pressure switch (I think thats what it is call..... has electric wire going into it).... nothing above that is leaking.
Was snowing this morning..... better picture later
So if i was to replace that... do I need to do a full drain in order to replace the oil pressure switch..... (if there is a guide already can someone point me into the right direction)
Thanks in advance, if need photo I can post where it is leaking from.
