Code P0133 -- 2004 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-20-2012, 07:40 PM   #1 (permalink)
View Dixon12's Photo Gallery
I'm getting close to 100K, and the check engine came on, code P0133. Got it scanned at Autozone, and replaced the O2 sensor with Denso that looked exactly like the stock. Some 15 miles later the check engine light is still on, and code still reads P0133. Does it take longer than that to clear or is it something other than O2 sensor? If so what could it be?
Dixon12 is offline   Reply With Quote
Old 01-20-2012, 09:23 PM   #2 (permalink)
Gameroom cash: $103000
View shoujiliuzhijun's Photo Gallery
Did you erase the code after the job? If so, did the temperature drop that day? The following TSB has this code included. Intake manifold gasket replacement is not too hard and the part price is under $10. You may want try it.
http://toyota.justanswer.com/uploads...rolla_0171.pdf
They're some discussion here about the gasket and other codes:
2004 Corolla P0171 code (system to lean)
shoujiliuzhijun is offline   Reply With Quote
Old 01-20-2012, 10:55 PM   #3 (permalink)
ASE Certified Master Tech
View MasterTecInSTL's Photo Gallery
P0133 is for slow response of O2 sensor #1. This is almost always due to a bad sensor.
I have a feeling that dixon replaced the wrong one. There is one up at the exhaust manifold and a second one down behind the catalytic converter. It is the one up at the manifold that needs to be replaced.
MasterTecInSTL is offline   Reply With Quote
Old 01-21-2012, 12:05 AM   #4 (permalink)
shoujiliuzhijun, thanks for the advice the link.
Nope, I did replace the upper one. That said, being new to Toyotas, I came pretty close to replacing the downstream sensor.
Old 01-24-2012, 09:22 PM   #5 (permalink)
MD1032's Avatar
View MD1032's Photo Gallery
I had this same problem (same code) with one of my old Hondas and after replacing the sensor three times, a random dealership I stopped in diagnosed it as incorrect wiring. Make sure you check the wiring.
Also, make sure you used the right sensor. The drive by wire ones (~2005 and newer) have a different sensor than the 2004 and older with a standard throttle body.
MD1032 is offline   Reply With Quote
Old 01-24-2012, 10:54 PM   #6 (permalink)
Thanks for the advise, all! Well, I doubt it's the wiring because the car's been in the family for years and it's a new problem. I replaced the sensor with a direct replacement denso that looked exactly like the stock toyota. The CEL went away after some 50 miles of driving, but then came back.
Gonna replace the intake manifold gasket on the weekend. Anyone has an opinion on the Fel-Pro brand ($4.80 at Advance Auto, or less with their online coupons)? And is it necessary to drain the coolant? I have some rubber plugs of assorted sizes and was thinking of just plugging the hoses while I do the repair.
Old 01-25-2012, 01:25 AM   #7 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
You better get Toyota's revised # 17171-22060 which retails for $5.62, or Victor Reinz # MS19590.
https://www.rockauto.com/catalog/x,c...LA%2B1.8L%2BL4
No need to drain coolant or remove throttle body coolant lines.
Originally Posted by invader View Post
1st pic shows elusive brake booster vacuum hose on intake manifold, which is hidden once throttle body is installed... Intake manifold gasket was easily replaced on friend's 2005 without draining any coolant or disconnecting throttle body coolant lines, by setting (+cleaning) throttle body aside.
invader is offline   Reply With Quote
Old 01-25-2012, 06:13 AM   #8 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $152550
View hardtopte72's Photo Gallery
I will add that when there was a huge (over 1000 gasket) back order for the new gasket at Toyota we used the Fel-Pro gasket as it was identical to the updated gasket and always fixed the issue.
But no sense in risking the issue with the gasket now readily available.
As far as the code did autozone guy clear the code or did you unplug the battery? It may be still set.
My Toyota list:
1982 Corolla SR-5 Hardtop 5 Speed Manual(R154) 1JZGTE
2005 Corolla CE 5 Speed Manual 1ZZFE
2009 Camry LE 5 Speed Auto 2AZFE
If I helped out in anyway please hit the thanks button on my post .
hardtopte72 is offline   Reply With Quote
Old 01-25-2012, 06:56 AM   #9 (permalink)
Neither. The autozone guy said they can only read codes, not reset them. And I didn't feel like losing all my radio settings by unplugging the battery. I don't know much about it, but thought that it would reset back to normal after some time even without a reset.
Old 01-25-2012, 02:04 PM   #10 (permalink)
Toyota Fanatic
Yes but that's over 32 key cycles. You probably still have the code stored. Write down your presets unplug the battery for one minute and hit the brakes a few times.
Then hook everything back up and see if it pops on again.
My Toyota list:
Old 01-25-2012, 03:10 PM   #11 (permalink)
Woodyg's Avatar
Gameroom cash: $138765
View Woodyg's Photo Gallery
If you have an android device you can buy a bluetooth elm 327 off of ebay for $15 and download torque for free. You will then have a code reader
2006 Vibe, White, 1zzfe, auto ( Toyota type IV), AWD, PW, PL, CC, AC, 161,000(5/12/2012)
1998 Camry LE, 4 door, Puke Green, I4(5S-FE), CA Emissions, Auto(A140E), 122k(3/22/2012), AC,CC, ABS, Built in Japan 04/98. Grandmas old car(acquired 7/22/2011), work= precat Denso A/F sensor, NGK wires.
Woodyg is offline   Reply With Quote
Old 01-25-2012, 03:18 PM   #12 (permalink)
Woodyg's Avatar
Also it is a good idea to reboot the ecu anytime you replace any sensor
