spyder extune catback. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2012, 03:14 AM   #1 (permalink)
View uhsenxrs's Photo Gallery
http://www.partstrain.com/store/deta...2081859705exsy
any one tried this before?
uhsenxrs is offline   Reply With Quote
Old 01-22-2012, 03:45 AM   #2 (permalink)
04 Corolla CE manual
Gameroom cash: $266401
View invader's Photo Gallery
Interesting T-304 stainless steel cat-back exhaust, especially for the price. It would require cutting your exhaust just past the catalytic converters, and clamping or welding the Spyder exhaust on like Magnaflow's system.
http://spyderauto.com/product.php?id...t-back-Exhaust
http://www.carpartsclick.com/product...id=p100-c25994
http://www.outperformanceshop.com/pr...cb-3161320.htm
invader is offline   Reply With Quote
Old 01-22-2012, 03:58 AM   #3 (permalink)
i thought these are all bolt ons, no cutting/welding
Old 01-22-2012, 04:13 AM   #4 (permalink)
If you have a look at your stock exhaust, you'll see that it's a single piece from manifold flange where the 1st cat starts, all the way back to rear axle where it bolts up to muffler section... You simply need to cut stock exhaust a bit past the 2nd cat, to clamp on the Spyder cat-back exhaust. It can also be welded on if the sealing at the clamp is inadequate.
Old 02-23-2012, 07:05 PM   #5 (permalink)
View TommyblazeHD's Photo Gallery
Do you get that Spyder exhaust for your Corolla? I did extra research and found out on their website that the exhaust piping is for this kit is 3 inches wide! That may sound good, but it's not! The little 1.8L engine can't move the exhaust gases quick enough for such a think pipe! It's like the gases will accumulate inside the piping quicker than the motor can push it out the rear. Does that make sense?
TommyblazeHD is offline   Reply With Quote
